135 hyd.
don ditmars
08-27-2007 19:45:16
My 135 had an ad-on hyd. control where the stand pipe comes through the rockshaft cover. It's really worn and bypasses all the pressure back to the resevor. I can make the 3pt work by blocking the bypass holes but am building too much pressure. I would like to put one of the original caps on but haven't been able to find one. The pictures I have seen seem to indicate that there is a pressure regulator built into these caps. Does anyone know, or know where to get one?
Thanks,
Don
DavidP, South Wales
08-28-2007 05:04:01
 Re: 135 hyd. in reply to don ditmars, 08-27-2007 19:45:16
Hi,
It is unlikely that there is wear in the stand-pipe. It is more likely to be bent. If your tractor does not have PRESSURE CONTROL you will be able to remove the pipe and check it. If you do you will not be able to. The cap does not have and regulating device in it.
The cap number is 180 908 M1, the blanking plug is 195 567 M1, the sealing ring is 195 561 M1.
Caps should be available from a breaker, MF dealer, e-bay or even your neigbhour might have one in a corner somewhere.
DavidP, South Wales
