Distributor Turning
Charles Story
08-27-2007 12:57:19
I was using my 135 Saturday, just idling around then all of sudden the distributor started turning jerking the spark plug wires off, I pulled distributor(bolt was tight on dist.clamp) and could not turn gear so my guess something broke in distributor housing. First time to see one jerk the wires off, glad a neighbor was there it was almost unbelievable. all suggestions appreciated
LenND
08-27-2007 14:48:12
 Re: Distributor Turning in reply to Charles Story, 08-27-2007 12:57:19
If it was rebuilt that soon shouldn't be too dry. More than likely something was dropped in the distributor and it found a permanent home.
CENTAUR
08-27-2007 13:41:53
If someone drops a Distributor point screw or nut when replacing points and/condenser and does not remove it will do what you describe in some cases. CENTAUR
Gerald J.
08-27-2007 13:22:41
Bearings in the distributor seized. You've been lax about their lubrication (oil wick under the rotor).
Gerald J.
Charles Story
08-27-2007 13:47:18
 Re: Distributor Turning in reply to Gerald J., 08-27-2007 13:22:41
I forgot to say that I had distributor rebuilt 2 months ago.
