MF-65 rear wheel
Mark Watkins Ky
08-26-2007 18:14:38
I need a little help once again. My MF-65 is in need of a rear wheel. The area around the valve stem is badly rusted out. This web site list two different wheel sizes. They are 10x28 and 11x28 wheel sizes. The tractor has a 14.9x28 inch tire size. Which wheel do I need??? Thanks...
david from mo
08-26-2007 19:28:02
 Re: MF-65 rear wheel in reply to Mark Watkins Ky., 08-26-2007 18:14:38
My 165 parts book shows 11*28 pavt rim
Mark Watkins Ky.
08-27-2007 18:14:08
 Re: MF-65 rear wheel in reply to david from mo, 08-26-2007 19:28:02
After putting a rule to it the tire seem to measure about 12 to 13 inches wide. It also has spin out type wheels. With 4 rails or couplings.
david from mo
08-28-2007 05:37:46
 Re: MF-65 rear wheel in reply to Mark Watkins Ky., 08-27-2007 18:14:08
I agree with you. I gave you the only 28 wheel in my parts book. I got a 15*28 for my 175 for 16.9* 28 rim.The old one was 14*28 ! it worked ok
Mark Watkins Ky.
08-28-2007 16:34:32
 Re: MF-65 rear wheel in reply to david from mo, 08-28-2007 05:37:46
I found a 12x28 inch rim with spin outs today. Do you think it will fit a 14.9x28 inch tire???
massey333
08-28-2007 18:44:47
 Re: MF-65 rear wheel in reply to Mark Watkins Ky., 08-28-2007 16:34:32
Mark,13"is the correct rim for a 14.9 tire,,But you probely only have a 12" now and a12"rim was used for a lot of years and worked fine,so YES 12" will be fine.If you were going tobe putting both on new then 13" would be the way to go,but your not so go with the 12".
Mark Watkins Ky.
08-28-2007 19:06:15
 Re: MF-65 rear wheel in reply to massey333, 08-28-2007 18:44:47
Thanks for the very useful information. Mark
