pto not disengaging
jb4020
08-25-2007 19:08:01
I have a mf 65 gas the i just put a new clutch in and today i went to hook up a brush hog and use the pto and i cound not get the engine pto to go in when i pushed the double clutch all the way down. What adjustment needs to be made? Thanks
Big Dean
08-26-2007 13:32:30
 Re: pto not disengaging in reply to jb4020, 08-25-2007 19:08:01
If you pulled the two parts of the tractor together with bolts you may have warped the PTO disc that usually does warp the disc. First you might try going up through the inspection hole in the bottom of the bellhousing and setting the clearance for the 3 PTO pressure plate stop bolts at about 0.050 to 0.060 to see if that will make it release It is not uncommon for them not to release when those bolts are set at what the book calls for.
jb4020
08-26-2007 17:35:10
 Re: pto not disengaging in reply to Big Dean, 08-26-2007 13:32:30
Thanks i will do that
