massey 35 hyd spool valve
tractor junkie
08-25-2007 14:05:24
I NEED TO FIND A SPOOL VALVE FOR A MASSEY 35.I NEED THE TYPE THAT SETS ON THE TRANSMISSION HOUSING.IT CAN EVEN BE A SINGLE SPOOL VALVE.I'VE HEARD THAT ALOT OF THE TRACTOR MODELS ARE THE SAME AT THE HOUSING.ANY REASON NOT TO BUY USED?ANY INFO APPRECIATED ON NEW OR USED.
DavidP, South Wales
08-27-2007 02:56:01
 Re: massey 35 hyd spool valve in reply to tractor junkie, 08-25-2007 14:05:24
Hi,
Generally all of the 'older' MF's have the same mounting point on the front of the hydraulic cover.
No problem with buying second-hand but if it has done a lot of work you run the risk of oil leaks.
Normally the spool and housing come in a matched pair so you would not be able to replace one without the other. Any sealing arrangements are normally to keep dust out rather than oil in.
DavidP,South Wales.
