Tire / Maintance Shops
Robert Barker
08-24-2007 17:12:50
To make a long story short, I blew two disks out in my back and had spine surgery about five weeks ago. During this time my TO-20 needed new front tires, tubes and full tune-up. Being limited in what I can do I search around and found two places in Granger TX to do the work.
For the tires and tubes a place called the Pit Stop was the ticket. Excellent work at a great price. Tire and tube with mounting was about 53.00 a side!
For the tune up / fluid change Precision Ag in Granger TX did the work. They changed all the fluids, cleaned the carb, added an inline fuel filter and much more for 250x.xx. They even fixed a tranny issue and didn"t charge. Very honest and the price was great.
I have nothing to do with these shops, but just thought I would pass it on for those in the central Texas area.
Thanks,
Robert
David Maddux
08-25-2007 07:02:25
 Re: Tire / Maintance Shops in reply to Robert Barker, 08-24-2007 17:12:50
It is nice to share info about satisfied results with service co's.
marlowe
08-24-2007 17:40:32
if they change the trans. and rear end oil what did the us to replace it with. i'll bet it's not mineral oil as should be
Don-Wi
08-24-2007 18:32:44
 Re: Tire / Maintance Shops in reply to marlowe, 08-24-2007 17:40:32
If they used a trans/hydraulic lube there shouldn't be any worries. That's the modern replacement for the mineral 90 wt. Even if the manula called for it in one of ours, I would run Perma-Tran III or something similar in it.
Donovan from Wisconsin
marlowe
08-24-2007 18:50:52
 Re: Tire / Maintance Shops in reply to Don-Wi, 08-24-2007 18:32:44
i have 5 to-20s and all run on mineral oil BUT they guys in shop [mine] mixed up the oil and put per. tran in two last summer and both pumps went out with in two days . i'll spend a little more and use M1103 in the summer al tractors see about 40hrs a week
