mf 202 carb woes
jack-iowa
08-22-2007 11:45:31
went out to my 202 to level some ground and turned the gas on and walked around and noticed gas flowing out the carb real good.
time for a repair I guess any clue what may cause it? stuck float or bad needles seats?
thanks
Aaron Ford
08-22-2007 12:54:34
 Re: mf 202 carb woes in reply to jack-iowa, 08-22-2007 11:45:31
Likely just a stuck float/needle valve. Turn the fuel off, take the plug out of the bottom of the carb and tap the sides of the carb with a wooden hammer handle. Replace plug, turn on fuel. Should seal up.
Disassembly would be the next step...
HTH Aaron
jack-iowa
08-22-2007 13:17:38
 Re: mf 202 carb woes in reply to Aaron Ford, 08-22-2007 12:54:34
thanks if it stops raining now will give it a try as it was fine.
