MASSEY HARRIS PONY TRACTOR
LESTER BRUBAKER
10-25-2000 04:32:44
WHAT ARE SOME OF THE PROBLEMS THAT I SHOULD BE LOOKING FOR ON A MASSEY PONY THAT I AM CONSIDERING PURCHASING? THE OWNER STATED THAT THE FLOAT IN THE CARBUREATOR IS POSSIBLY LEAKING CAUSING SOME CARBUREATOR PROBLEMS. ANY OTHER RED FLAGS THAT I SHOULD BE AWARE OF????? PLAN TO USE TRACTOR TO PLOW GARDEN MOW GRASS AND PUSH LIGHT SNOW. THANK YOU LES BRUBAKER
Jason
10-25-2000 17:43:18
 Re: MASSEY HARRIS PONY TRACTOR in reply to LESTER BRUBAKER, 10-25-2000 04:32:44
Don't punch your tractor. You could hurt you hand!! HA HA. Don't fill bad I was once in your shoes. First Re build the carb. Make sure there is a good seal between the carb and manifold. The problem I had was pressure building up in the gas tank. It would not get a goog flow of gas. I fixed this buy drilling a small hole in the gas cap. THere are many other things I tride allso but this seamed to have the biggest affect. I just got done with my 52 Pony, Ihave had my share of problems such as transmition,clutch,exc. I you need any help just write [email protected]
