180 crankshaft seal
Mike Tirey
08-19-2007 21:47:45
Has anyone replaced a front crankshaft seal on a 18o without tearing frontend down.is the seal pressed in from the front.
Tom Dold
08-21-2007 13:53:55
 Re: 180 crankshaft seal in reply to Mike Tirey, 08-19-2007 21:47:45
Mike
A MF 180 could be a Continental gas, Perkins gas or Perkins diesel. At any rate you should be able to change the front seal on any of them without removing the front cover the Perkins engines both use the same seal. It would be best to remove the front axle at the casting. The hardest part is getting ther old seal out.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
[email protected]
