Weight of a MH 44-6?
Dalton S.
08-19-2007 21:21:47
How much does a Massey Harris 44-6 gas wiegh? I know the MH 44-4 weighs 5800 lbs because of the Nebraska tests. Will a 6 cylinder weigh that much more? It cant be over 6500 lbs. Well I hope it doesnt weigh any more than that or it will exceed my trailer capabilities. Any advise is greatly appreciated.
Dave_Id
08-22-2007 15:17:20
 Re: Weight of a MH 44-6? in reply to Dalton S., 08-19-2007 21:21:47
Standard 4200#'s, Rowcrop 3600#'s. Shipping weight according to Massey Tractor Data Book
mh446
08-20-2007 13:24:36
i have a 1947 44-6 and i weighed it with me off it was 3760 lbs that is with the mechanical lift off also with it on add about 40 lbs
msb
08-20-2007 17:23:43
 Re: Weight of a MH 44-6? in reply to mh446, 08-20-2007 13:24:36
1947 44-6 Row Crop??? Where are you located? Any chance the block has been welded? Trying to find Dad's 44-6. No longer have the serial number. Thanks ,bob
mh446
08-20-2007 22:42:16
 Re: Weight of a MH 44-6? in reply to msb, 08-20-2007 17:23:43
yes block has been welded ,live in central missouri
msb
08-21-2007 12:15:35
 Re: Weight of a MH 44-6? in reply to mh446, 08-20-2007 22:42:16
Any chance you would sell it?
ACEd
08-20-2007 05:33:24
I one reference that says 44-6 std 4200 pounds, 44-6 RC 3600 pounds but found another reference that says shipping weight 44-4 Std is 4500 pounds vs 44-4 Row Crop 4165 pounds - agree 5800 is ballasted - so unless you have the aux weights (typically 150 pounds per weight per side on rear) and/or cast rear centers and/or fluid in tires (recommend you drain & reinflate) you are probably closer to 4000 +/-200 pounds.
ChuckBergstrom
08-20-2007 04:45:51
Dalton, The weight of a 44-6 (shipping wt.)is
3600 lbs. This is without fluid in tires. A 44-4
is only slightly more. It is when tested with the
cast wheels and other equipment that the weight
rises. Chuck
