Replace PTO Seal
William F. Moor
08-18-2007 17:17:59
Need to replace seal in PTO of MF 135. Is their a diagram to show parts and what tools are required.
Big Dean
08-19-2007 13:07:46
 Re: Replace PTO Seal in reply to William F. Moorehead, 08-18-2007 17:17:59
I have a picture showing what is involved in replacing the PTO seal with instructions on it. I will email it to you if you will send me an email address to send it to.
David, Surrey UK
08-19-2007 05:10:30
On p. 81 of the I&T shop manual there's an exploded view of the PTO shaft assembly. The text says:
[quote:be7e8ca2ec]To remove the pto output shaft, drain the transmission and hydraulic system fluid and unbolt rear bearing retainer from rear axle center housing. Withdraw shaft, rear bearing and seal housing as an assembly. Rear bearing, seal or sealing "O" ring can be renewed at this time, as can shaft or seal retainer.[/quote:be7e8ca2ec]
David
