engine block
Jim McMullen
08-16-2007 12:12:39
I have 135 diesel no number plate and I want to rebuild the motor because of a bearing on the crankshaft.Can find out by numbers on the block as to what engine it is.
Jim McMullen
08-23-2007 10:42:22
 Re: engine block in reply to Jim McMullen, 08-16-2007 12:12:39
Okay that # is 2313139 C WERE do I find out the year and were it was made.
Jim McMullen
08-22-2007 10:12:41
Okay I now have all the numbers I could find on MY tractor (massey 135). On the left side looking faorward from the seat, top #2313139 C below this T-14 below that #37111450 and below that MON O CY1 WITH ALONE #5 below that and on the bottom GKN 1842. Right side only the #5. Left side of the trans #894-682-M1. Right side of trans starting at the top L-21-M BELOW THIS a diamond shape with what looks to be three houses in side of it with writing STER 1AT NOT SURE OF THIS PART. And last the right side of the axle #897-719-M1 AND BELOW that M30 MN
DavidP, South Wales
08-16-2007 14:04:50
Try looking on the small flat area above the main fuel pump on the left hand side. If it is a UK made engine it may start something like '152 UA....'
DavidP, South Wales
