MF 3 Baler
Dave Goldthorp
08-13-2007 13:56:35
I don't have a part number or actual part name as I only have the User Manual for my MF 3 Baler. I need to replace a broken part. I will name it the 'pickup arm guide bracket'. Looking into the pickup chamber, there are 4 pickup arms that hold the pickup tines. On the left end the pickup arm there is an 'L' shaped bracked with a 1 1/4" bearing. Each bearing engages into a cast elongated wheel and when the pikup drum is rotating these guide brackets rotate the pickup arm, tucking the tines as they enter the pickup chamber and then extending them again for pickup. My problem is that 3 of the brearings have come off but they are unique and not available as a replacement. The complete guide brackets are availble but very expensive and together worth more than what I paid for the baler. The baler bales and ties well but with only one pickup arm, not very effective. Does anyone know if second hand parts are avilable or of any balers no longer functioning but with the pickup guide bracket still in tact. I am a hobby farmer baling about 1000 bales a year. Thank you to anyone who may be able to help me.
Dave Goldthorp
Tom Dold
08-13-2007 15:15:03
 Re: MF 3 Baler in reply to Dave Goldthorp, 08-13-2007 13:56:35
Dave
The bearing you are referring to is riveted to the tine bar crank. I have 2 used assemblies. The rollers appear to be ok. I also have to new rollers only MF part #6872631M91. They have to be riveted to your exsisting tine bar crank. I beleive these are still available from Agco.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
[email protected]
DavidP, South Wales
08-13-2007 14:47:05
Hello Dave,
Can't help you with sourcing the bits but the items in question are the tine bar cam bearings.
Cheers
DavidP, South Wales
