No pix - try the picture gallery. Might be something there. They"re called stay bars in the parts book, used to convert the 3-point drawbar to a fixed height drawbar. They look like the strap type sway bars, about 3/8 x 2, with a 7/8 hole on the bottom and 3/4 at the top. About 2" at each end bent to suit the angles needed. The lower ends fit on the ends of the 3-point drawbar inside or outside of the sway bar straps. The top ends fit on the top link pin. The factory ones are adjustable, in two pieces and slots like a generator adjusting bracket, and a couple of 3/8 bolts to clamp them together. If you need an adjustable setup you can do the same thing with bolts spaced about 10" apart and holes drilled as needed. The factory ones have about 5/8" at the top folded 90 degrees to the outside; the Oliver ones were bent to the center - to keep the bars from flopping on the top pin. The pins on some 3-point drawbars are too short to take both sway bars and stay bars. The work-around: thin the lower ends of the stay bars and the outer ends of the sway bars with a grinder (minimum safe thickness about 3/16"), possibly take a bit off the flat side of the snap pins. This weakens both the sway bars and the snap pins. This is not critical in this situation, but they could fail in normal use for other applications. A new set of each is a lot cheaper than the remote valve!
