help!!! mf-35 stuck in first gear
ric1
08-11-2007 11:07:34
i have a mf-35 that got stuck in 1st gear while brushhoging i went to go to 3rd low from first hi the low hi range still works but the other shifter wont move at all. i have had it to get stuck between 2 gears befor and i could take the fill plug out and just line things up with a small bar but this time nothing inside will move. i thought maybe someone out there somewhere has experienced this problem .
thanks any help will be app. RICK
Scott in Australia
08-12-2007 17:18:38
 Re: help!!! mf-35 stuck in first gear in reply to ric1, 08-11-2007 11:07:34
Ric,
Big Dean and others on the forum will recommend that you always push DOWN on the gear shift when changing gear - apparently this helps to prevent jamming.
Scott
DavidP, South Wales
08-11-2007 11:15:35
Hi,
Stuck in gear is not normally a big problem as you have found out from experience.
Make sure there is no tension in the transmission.
Block the clutch pedal down. Make sure the tractor is free to rock back and forth. You could even jack one rear wheel clear of the ground. Block the front wheel and let the brakes off.
Are you sure you are pushing on the right selector?
Looking through the oil fill it will be the furthest one that needs to be moved rearwards.
Check for wear in the gear lever pivot pin and cup.
Cheers
DavidP, South Wales
ric1
08-11-2007 12:00:41
 Re: help!!! mf-35 stuck in first gear in reply to DavidP, South Wales, 08-11-2007 11:15:35
hi david when i look through the fill hole all i can see is somekind of cover looking part with a small square headed bolt with a piece of wire through it to hold it in place. its been a year or so sence i have looked in here and i dont remember seeing this part. looks to me like it needs to be moved one direction or the other so i can see to line things up. its right there staring right at me not letting me see anything hope this makes sence RICK
ric1
08-11-2007 12:31:37
 Re: help!!! mf-35 stuck in first gear in reply to ric1, 08-11-2007 12:00:41
i got it fixed after eating some dinner i thought about what you said. i went back out looked it over more throughly with a flashlight and slid the large gear toward the rear and thats all it took. thanks for your help david
David Box
08-12-2007 20:20:02
 Re: help!!! mf-35 stuck in first gear in reply to ric1, 08-11-2007 12:31:37
Glad to help. I keep a long screwdriver and a wrench for the plug in the fender box for this purpose. It seems mine hangs up when the front end is pointed down a steep hill and I try to go to reverse.
