MF 35 fluid check and gas tank bolts length
NCCub
08-10-2007 17:27:42
Two questions: Where do I check my differential/tranny fluid? There is a bolt with two flats with a set screw on the side near it that I suspect is it. how long should my bolts be that suspend the gas tank above the engine? Mine is not level, jacked up in front but both look two high. No hood on unit, it is a 1963 massey 35 gas.
Thanks
Kerry
C. T. in Oklahoma
08-11-2007 08:57:10
 Re: MF 35 fluid check and gas tank bolts length in reply to NCCub, 08-10-2007 17:27:42
Kerry,
I have a dipstick on the right side towards the rear, near the differential lock. I can't help on the gas tank, but somebody will.
C. T.
