Mf 135 and Multi- power
Kevin Curley
10-23-2000 05:04:35
As usual, ask the questions after the deed! I've purchased a 1966 MF135 this week-end, and it has multi power. Is this a problem? Its working now but i expect I won't often be using the travel setting, is it better to leave it alone or use it occasionally to keep it operable?
mohammad
10-26-2000 22:55:30
 Re: Mf 135 and Multi- power in reply to Kevin Curley, 10-23-2000 05:04:35
hello
i need many information from tractors
please post mail
bbott
10-23-2000 16:34:56
I've always been told you should run them in 'high' periodically... it has to do with keeping parts lubricated properly down below.
So, I run around in high mostly.... but....
Low makes it a lot easier to shift, especially when stopped, so I've got in the habit of putting it in low to change gears or when I stop.
bb
Jim from Stonepile
10-23-2000 16:29:06
Kevin, Suggest you use the "travel setting" or high. in low you don't have any engine breaking ability- in other words you are free-wheeling down hill! Also if you have trouble- clean the filters and change the Transmission-hydraulic oil. Have had a '66 135 bought new And has been great. Enjoy!-JIM
Jack in NB
10-23-2000 09:24:49
Hi neighbour -
I see you were out of bed well before breakfast this morning!
We've got two of them; it doesn't seem to make much difference whether you use the multi-power or not. When they're ready to act up, they will!
Enjoy the new tractor - they're excellent machines.
Jack Wetmore in Fredericton
Ross Craig
10-23-2000 13:55:03
 Re: Re: Mf 135 and Multi- power in reply to Jack in NB, 10-23-2000 09:24:49
my 1963 35 special deluxe has multi power. it works well, just as everything on this 37 year old beauty does.
