MF35 Multi-Power
John E. White
08-08-2007 20:55:18
Where can I find information on the multi power feature? I have the 3 cylinder diesel and to get motor braking I'm supposed to put the multi-power lever in high. This used to work but no longer does.
ChuckBergstrom
08-09-2007 05:24:25
 Re: MF35 Multi-Power in reply to John E. White, 08-08-2007 20:55:18
John, You can try adjusting this way: With the
multi-power lever at the up position, follow the
linkage down to the trans. There is an arm that clamps to a tiny rod that goes into the top of the trans. loosen that clamp from the tiny rod,
push the rod downward as low as it goes and then
retighten the clamp to the rod. Should work, Chuck
