MF 30B
JoeFix
08-04-2007 22:10:30
After reading at least 10 post refering to stuck in reverse, I also went to Big Dean's web site. I have not been able get it out of reverse. The left shifter is High and Low, I place that in neutral position, put the little lever (S-N-H) in neutral position. If I start the tractor then move the little lever into "S" position the 3 point hitch lifts up when I push the forward pedal it drops. If I move the left shifter into High or Low it is in reverse and if push the forward pedal it stops moving like its in neutral.
suptscottyb
08-05-2007 06:37:07
 Re: MF 30B in reply to JoeFix, 08-04-2007 22:10:30
This is a shuttle shift trans? Do you have two throttle peddles? You didn't say what is happening with the reverse peddle. The trans is a 2 speed / hi - lo type. The forward and reverse throttle pedals work the same in any configuration of the shifters. Need more info...
suptscottyb
08-05-2007 06:37:06
JoeFix
08-05-2007 17:41:25
 Re: MF 30B in reply to suptscottyb, 08-05-2007 06:37:06
Yes there are two throttle pedals. when the trans is in hi or lo it is stuck in reverse and will go backwards when no pedal is pushed and when the reverse pedal is pushed
135 Fan
08-05-2007 21:41:50
 Re: MF 30B in reply to JoeFix, 08-05-2007 17:41:25
It is a totally different tranny from the 6 speed manual used on AG tractors. Dave
suptscottyb
08-05-2007 20:11:51
Sounds like more than one problem I can think of.
Maybe someone (Big Dean or David) who knows these "instant reverse" trannys can jump in here.
You can post "Question for Big Dean..." if nobody answers this. Good luck.
