MF 65 Diesel Transmission/Diff oil
Dobbins
08-02-2007 17:36:12
Fellas,
This is a very simple question that I don't seem to be able to find an answer for online. What type of lube is meant for the transmission of a 65 diesel and where do I add it to the tractor? I think I know, but the shop manual is absolutely no help in confirming. My 235 has a filler just forward of the main gearshift lever and I figure that's where you add lube to the 65 as well. Any help is appreciated!!
Buttsbrooke
08-02-2007 23:34:26
 Re: MF 65 Diesel Transmission/Diff oil in reply to Dobbins, 08-02-2007 17:36:12
I have a 1960 massey 65 diesel as well. Original owners manual states using Mineral oil or SAE 80. I made the mistake of putting Permatran transmision oil in once, created a creamy mess. Permatran and other newer transmission oils were made to absorb and carry water evaperants to a filter much like hydralic systems. Older tractors dont have a filter system in them. the oil was ment to be separated from the water and be drained off on a routine bases. Typically the only water that should be entering will be condensation due to having an open space gear case. Use SAE 80-W90 or SAE 80. Reminder, hydralics use the same oil from the transmision case as well. The fill cap is located to the left of the main shift lever on the transmission case.
