NEED HELP! M-H 22
Sam in PA.
07-29-2007 16:57:03
Hello. I don't have a manual for my "22". Where & how do I check transmission & rear end fluids? Can't seem to find oil level plugs anywhere. Thanks for any & all help. Sam
Dick in NY
07-29-2007 17:51:26
 Re: NEED HELP! M-H 22 in reply to Sam in PA., 07-29-2007 16:57:03
Sam, You should really get a manual for your tractor ( on this site or elsewhere ). On the MH 22 the transmission and differential housing are divided by a wall in the case. The tranny case contains 2 gallons of SAE 140 and the level plug is on the left side under the platform behind the clutch pedaL. The differential case holds 13 1/2 Quarts SAE 140 and the level plug is in the center of the rear of the tractor below the pto.I hope this helps you. Dick
