150 Fired Up, After DA Attack
Tom from Buckey
07-28-2007 06:13:16
Well, I got the Z145 running after a complete rebuild, but took over an hour to get it started. Ya,see I had the distributor out 180' but still a no start. Pulled plugs and put gas in cyl's, started right up for a couple seconds. I'm thinking float stuck in rebuilt carb. Pulled carb tore apart, no problem there. While hooking temp fuel tank (lawn mower tank) back up I opened the inline valve, no fuel flowing.
What a dummie I am, there was a second shut off valve at the tank that I missed. Opened both valves, pulled choke, hit starter, and it runs.
Now if I just had the front pedistal back from machine shop, I could mount the radiator and run it long enough to set timing and torque her up.
Just another day in the garage.
