Removing duals adjusting wheels on a large MF
chuck
10-18-2000 14:52:05
I have a 1105 with 3.25" round axle,i removed
the duals & want to loosen the hubs to slide the
inside rear wheels out. The manuals way dosent work or un stick the wheel
from the hub. Does anyone have experience with this?
Merle
10-20-2000 20:13:10
 Re: removing duals adjusting wheels on a large MF in reply to chuck, 10-18-2000 14:52:05
Chuck
First clean all the dirt out of the two empty holes next to the four bolts holding the wheel on the hub. Next remove the four bolts and insert two of them back into the holes you just cleaned out. Run them both in until they just touch the hub. Now give each bolt a half a turn each until the wheel pops off the hub. Take care at this point as those wheels are very heavy and will kill you if they fall on you. Once the wheel is removed from the hub wedge a screwdriver in the crack on the hub just enough to loosen it. Don't get to carried away at this point as the hub is easly broken. Now look for a wire snap ring in the groove on the axel, sometimes they are installed and sometimes not it will have to be moved if you are sliding the hub in it's direction. Good luck and let us know how things turn out.
Merle
