MF 35
crazzzy_frooog
07-26-2007 08:21:11
I have a MF 35 that I could use some help on please. Serial # SDM151051. Rear housing # is MHF 183-253-M5. Tranny housing is MHF 182-840-M2. Any info would be a big help. Now It"s stuck in 2nd gear I believe, and the stick is in neutural. I know I can reach thru the filler plug with a long screwdriver. Do I need to push the gears forward or back? Please HELP!, Need to get this thing going.
Dave Sherburne NY
07-26-2007 17:02:25
 Re: MF 35 in reply to crazzzy_frooog, 07-26-2007 08:21:11
I just did that a couple of weeks ago, get a flashlight so you can look down there to see what your doing, then its easy. Then try not to lift up
on the lever when you shift.
crazzzy_frooog
07-26-2007 18:07:02
 Re: MF 35 in reply to Dave Sherburne NY, 07-26-2007 17:02:25
Thanks, I wasn't the one that pulled up on the shift. I know they are known for it. I'm still trying to find out more about this tractor.
Gerald J.
07-26-2007 10:42:16
The gear slides in the opposite direction the shift lever knob moves.
Gerald J.
crazzzy_frooog
07-26-2007 18:01:51
 Re: MF 35 in reply to Gerald J., 07-26-2007 10:42:16
thank's, that will be a major help.
Mr Bob
07-26-2007 09:42:13
I've unstuck these tractors by jostling the long screwdriver back and forth until I hear it snap free.
crazzzy_frooog
07-26-2007 10:02:00
 Re: MF 35 in reply to Mr Bob, 07-26-2007 09:42:13
thank you, I will give that a try.
C. T. in Oklahoma
07-26-2007 19:46:49
 Re: MF 35 in reply to crazzzy_frooog, 07-26-2007 10:02:00
This is straight from Big Dean - "Getting the main shift lever unstuck
Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear. If hung in second or third gear you have to pry on the shift fork you can see through the filler hole. if hung in second pry the fork toward the front of the tractor. If hung in third pry the fork toward the back of the tractor. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them".
crazzzy_frooog
07-27-2007 04:01:18
 Re: MF 35 in reply to C. T. in Oklahoma, 07-26-2007 19:46:49
Thank you very much. I printed this out to keep for the next time. Hopefully it doesn't happen again.
