236 loader on a 255 MF
Steve Garrett
07-22-2007 11:09:53
Does anyone know if a MF 236 loader will fit a 255 Massey w/a Simms Cab already on the Tractor. And would it take much alteration to make it fit? Thanks
Chuck Bergstrom
07-23-2007 05:26:09
 Re: 236 loader on a 255 MF in reply to Steve Garrett, 07-22-2007 11:09:53
Steve, The 236 loader is a nice fit for the 255.
I am aquainted with the Simms cab but don't know
about the fit. In the 236 parts book it does show
some mounts for cab and some w/o but I think most
dealers ordered brackets for cabs just in case.
Hopefully someone will have tried with the Simms.
Chuck
Steve Garrett
07-23-2007 18:31:32
 Re: 236 loader on a 255 MF in reply to Chuck Bergstrom, 07-23-2007 05:26:09
First of all Thanks to all with ideas! Chuck if you could find the info in the 236 manual regarding mounts it would really help. Email if you get it Thanks Steve
Gerald J.
07-23-2007 12:34:26
With the valve on the loader, it might take some adjustments in the valve operators, like running the valves with remote cables, or extending the plumbing and mounting the valve inside the cab. I've seen both schemes in other loader manuals.
Gerald J.
Gerald J.
07-22-2007 16:53:44
You will probably have to find the right brackets. MF sold the 236 loader to fit from 135 to 274 and most all in between. With the rear posts the way they are and the valve on the right post, there may be interference with getting into the cab. It was too much loader for my MF-135 so is now on mounts I made for it to fit on my JD-4020 which hasn't permanently bent it yet. I cross drilled the knobs of the valve handles and ran rods from them to a rod guide on the fender about three feet to the rear.
I know the manual lists many tractors the 236 fits. I don't know where my MF-236 manual is at the moment so I can't look for the 255.
On the 135, the front mount bolts to the bottom of the front axle support in front of the front axle and the rear mount bolts to the bottom of the clutch bell housing.
Gerald J.
