Hydraulic control valve MF 1100
Dave
10-16-2000 07:47:34
The body of the hydraulic control valve on my 1100 MF has a crack in it. It is a two segment valve made by Cessna. MF wants $1500 to replace it. I would like any opinions on replacing the complete valve with a jobber valve. I know I can get one for $300-$500. Who would be a good supplier? Thanks. Dave, Alberta, Can.
vinod maheshwari
11-14-2001 10:37:22
 Re: Hydraulic control valve MF 1100 in reply to Dave, 10-16-2000 07:47:34
I AM HYDRAULIC LIFT PARTS MANUFACTURER IN INDIA.KINDLY SEND PHOTO AND OEM PART NO. OF MF
OF THAT CONTROL VALVE
WE ARE MANUFACTURE AND DEVELOPER OF PARTS
I HOPE I WILL BE ABLE TO SOLVE YOUR PROBLEM
WHERE YOU ARE LIVING? CAN YOU SEND US YOUR POSTAL ADDRESS.
THANKS VINOD MAHESHWARI
R.V. AUTOMOBILES,393,VIVEK VIHAR, SHYAM NAGAR, JAIPUR-302019 INDIA
shafiq
12-13-2005 05:08:03
 Re: Re: Hydraulic control valve MF 1100 in reply to vinod maheshwari, 11-14-2001 10:37:22
dear sirs,
i am interested to buying massey tractor control valve.plz contact me as soo as.
chuck
10-18-2000 06:23:31
 Re: Re: Hydraulic control valve MF 1100 in reply to Merle, 10-17-2000 20:16:31
call 1-800-488-3407,get them to send you a catalog.I have a MF1135 & MF1105 which should be
the same hydraulic system as the 1100. I needed to replace the lift valve on 1135 & add
several remotes to the 1105.They use (closed center) valves & you can add as many to the system
as needed.New 3 spool valves run around $200 & hookup is very simple,email me if you got any
questions about connections. Chuck in NC
