Weight of MF 135
Fred Baker
07-20-2007 08:22:59
Hello from a lurker!
Am looking at a tractor, and from what I see here I will buy it to replace my Ford 9N. . (I saw someone else doing the same thing!) It is an MF, my brother the current owner says a 135, but my notes are a bit blurred as I was drooling. The tag said MF 202, s/n JGM308718, and it has a model 202 Loader. I may have the loader and the tractor models mixed. . I checked the archives for the model and weight, but found only reference to a model 40 at 4650#. In any event, I need to know what it weighs so I can arrange for a big enuf trailer. It does have liquid filled tires, so I need to add 1000# to the base weight. Or, if actual weight isn't available, will an 8500# trailer be enuf?
Thanks for your help
Fred - burning up in Utah!
Big Dean
07-20-2007 15:59:56
 Re: Weight of MF 135 in reply to Fred Baker, 07-20-2007 08:22:59
The serial number JGM 308718 is for a MF202 industrial tractor built in 1963 Years Built was from 1958 to 1967 The J stands for Industrial the G stands for gas engine the M is for a dual clutch or better known as a two stage clutch. The dry weight for them is 3350 LB. add a 1000 LB for the loader and another 1000 LB if the tires are loaded with fluid. Be low are some of the Specs for the MF202 Engine Continental Z134
No. of Cyl 4
Fuel Gas
Horse Power 35
Transmissions
6 speed 6 forward & 2 reverse
Manual Shuttle Instant Reverse or the early reverse-o-matic same
Fred Baker
07-21-2007 15:26:34
 Re: Weight of MF 135 in reply to Big Dean, 07-20-2007 15:59:56
Thanks for the help! When I get the tractor I will get some photos. . It is in need of paint, but it has a good heart!
Thanks again!
Fred
JJ. in BC.
07-20-2007 13:09:42
If it is a "135" you can figure about 3500lbs plus loader plus liquid in tires..... .JJ.
