Head re-torquing
Daryl9
07-18-2007 11:49:51
Should the head be re-torqued after the head gasket is replaced on my MF35 with the 4 cylinder Continental gas engine? If so, after running how long, and re-torquing with the engine warm or cold? And should this occur just once, or again after running for a while?
Bill Brox
07-20-2007 07:58:11
 Re: Head re-torquing in reply to Daryl9, 07-18-2007 11:49:51
Hello Daryl9
There is normally two ways of retorquing the head bolts.
In the old days, the head nuts or bolts were torqued down to a specified torque, using a torque wrench.
On newer engines it has become more common to torque the nuts and bolts to only maybe half the desired torque, and then turn the nut or bolt a specified amount of degrees extra. Let ut say, you torque the nut to 75ft. lbs, and then you turn the nud 90 degrees after that.
In your case you have such an old engine that it is most likely the first method that applies, and then the common thing is to start up the engine after it is torqued down in several steps until fully torqued. Let it run for about 1 hour, do not stop it during this time. After one hour, you stop the engine, and go to the first nut/bolt in the torque sequence, and loosen this, loosen it 90-180 degrees, and then torque it to the specified full torque. No steps this time, just torque it fully. After that you proceed to the second nut/bolt in the sequence and do the same. So, only one bolt is loosened at a time, and fully torqued before you proceed. Do this until every bolt is torqued.
After this you need to readjust the valves, because they have now gotten too little clearance.
I have never heard about any second retorque. Just one retorque after the first and initial warm up of the engine. And, the engine should not be under load during the 1 hour warm up. Just fast idle.
This is the way I have learned to do it.
The second method, using half torque and then a specified amount of degrees is a more accurate way to do it, but then someone must have told you the right torque, and the right amount of degrees to turn the bolt.
This is not the case for older engines.
Use engine oil to lubricate the threads after you have cleaned them so the nuts/bolts does not stick while torquing them.
This is in fact the excuse for halftorquing and turn a specified angle. The friction between the hole and the bolt or the bolt and the nut increase as you turn the nut/bolt more. And the difference in the friction increase between one nut/bolt and the other. So, using a fully torque means that there will be a difference in the actual pressure on the nut/bolt from bolt to bolt around the head. That is why the engine builders have started torquing only half the torque, because so early in the torque the difference in the friction is very small. And, when you then turn the nut/bolt 90 degrees or whatever the manual says, the bolts will have the same stretch, or very close to.
Well, sorry it got a bit long. Good luck.
Best regards, Bill
JJ in OK
07-19-2007 19:18:10
Daryl9: I used a 5/8 in socket that I cut down to just enough of the depth to cover the head of the bolt. I used an inch pound touque wrench. The combination was just enough to fit in the side of the head. The touque wrench was set at 840 inch pounds. I used 70 foot pounds converted to inch pounds= 840 in lbs. I tried several different combinatons of wrenches and this worked the best. Good Luck! JJ
Daryl9
07-19-2007 07:38:02
Last night I went around the head and re-torqued everything, but with the engine cold. Every nut was down about 10 ft-lbs after about 5 minutes of running two nights before, so it does seem that this is pretty critical.
And yes, the rocker shaft definitely has to come off, but with only four bolts you can get it off pretty quick.
I like the idea of running the engine from an old lawn mower tank - slick idea! The block heater idea is good too - but I don't have a block heater....
BTW, what is everyone else doing about getting the torque wrench on the bottom row of bolts adjacent to the spark plugs?
Tom from Buckeye Lake
07-19-2007 06:40:17
OK, my project 150 with the Continental Z145 "gas" is about to fire up. I have been reading about retorquing the head bolts. The problem is that to get the socket on the center row of bolts, it looks like the rocker-arm shaft must come off. Wont the engine be too cool by the time I get there? I'm going to use a fuel tank from an old lawn mower to supply it, so no problem with removing the tank.
Don-Wi
07-20-2007 14:37:14
 Re: Head re-torquing in reply to Tom from Buckeye Lake, 07-19-2007 06:40:17
It'll only be too cool if you hurt yourself while taking the rocker back off and hafta go get bandaged up at the ER. The engine will stay plenty warm long after you get the rocker off, re tourqued, and put back together.
I had my Oliver 1600's engine rebuilt but I never retourqued it after running it, and that was a big mistake. Ended up blowing the gasket withing 12 hours of use on the blower. Nothing too serious, but it was putting combustion gas in the radiator and it ran a little hot.
I didn't have to pull the tank on that one as it's behind the engine. I ran it for about 30 minutes or so then took it back apart and retourqued it, and since then I've put 100 hours on it no more problems.
Donovan from Wisconsin
Danperkins
07-18-2007 16:49:29
One little trick that I have used in the past is to fully assemble the engine after torquing the head, then fill it up with coolant and plug in the block heater overnight. It will heat the engine up to operating temp if you put a blanket around the engine, and It will save you the time of having to remove the fuel tank on tractors with the tank over the engine. Its very important to retorque the head when its hot. This also makes setting the tappets easier.
JJ in OK
07-18-2007 12:33:14
I recently replaced the head gasket on my MF 65. I re-torqued the bolts after running for about 5 min. I then did it again after 15 min and then again after about 30 min. I had to replace the head gasket because the last owner didn't re-torque after running for a while! Better safe than sorry. JJ
