jump starting 175 D
gtmerkley
07-15-2007 19:43:02
has any one out there found a way to jump start a 175 D ? I have tried jump starting mine several times using jumper cables, jumper boxes, charger on boost, even all 3 at the same time.But if I'm out in the field I have to take the battery out of the tractor and charge it then put it back in. The starter is new its been tested but no luck any ideas?
kuntryboy
07-16-2007 18:58:01
 Re: jump starting 175 D in reply to gtmerkley, 07-15-2007 19:43:02
i put the positive on the battery post at the starter and ground to the foot board. are you using a big enough battery to jump start a diesel?
brianriver
07-16-2007 08:51:37
Start with simple things, have batteries load tested, charging system output tested and check voltage at the starter when cranking good and cranking bad. You may have poor connections at battery posts, or at key and saftey switches or bad cables as well.
