All of this haying we are doing is proving that a second tractor could help speed up production - One of us could be baling and the other gathering the bales, or mowing and raking, or discing and seeding/fertilizing.Our neighbor is offering us his Massey Ferguson 180 that he no longer uses- it's too big for his uses- He is loaning it to us to see if we like it. It has a perkins 4-cylinder diesel, two stage clutch and Multipower, and has aprox. 8800 hours on it. It is in fairly decent shape considering it spent most of it's time outside. Our first "Work test" in baling the last of our hay is pretty positive. It's got lots of power, and the PTO seems to work okay. We'll hook up our big CaseIH 14' disc to it and see how well it pulls it. My (Mechanical) observations with it are: -Engine starts fine. Occasionally likes a puff of either when starting. Smokes (light blue) a little. -Engine does have an oil leak that seems to originate from head gasket. -Transmission is a little noisy when moving. -Brakes are hard to push. You need to really lean on them to get good braking power -Fenders have a bit of corrosion on them. Seat suspension needs work (Gas shock is toast). Seat cushions - What seat cushions? -One rear tire is new; other one must have spent a lot of time on pavement. The questions I have to ask you guys is:
Anybody have expiriences with the 180? what do you think?
What's a good test for the transmission and the Multipower? Discing sounds like a good test, but are there any others? How does the multipower work, and how can I test it? What problem symptoms should I look for? Any other suggestions for work tests I can try out on this guy? There is a foot pedal on the right hand side of the operator's platform, near the seat. What does it do? I'm assuming it's a differential lock, but I can't get the pedal to move. Is there a good MF Forum that you guys can recommend? Thanks!
