MF35
keith stromberg
07-15-2007 15:11:56
Have a MF35 1960 model I haved a I&T manual but this is not covered in it that I have found. On the rear center housing. The arms that attach to the implment (one on each side) Were it conects to the housing it is very loose I tried to see if it would tighten it but no go. What do I need to do? As I have said I am very greeen with all of this. Thanks very much fr any help
Keith
Aaron Ford
07-15-2007 19:48:55
 Re: MF35 in reply to keith stromberg, 07-15-2007 15:11:56
The lower lift attachment points should have a taper fitted pin and a large nut inside the axle trumpet. Requires axle removal. Big job, but if you are gonna be in there anyway on account of seals or brakes, do not overlook it.
HTH Aaron
Rod in Smiths Falls, ON,
07-15-2007 17:15:03
Keith:
Those arms are loose for a reason. Get used to them flopping around. They'll be fine.
I have the same model and year as you. It's a dandy tractor for many jobs. Don't hitch a chain to the upper part of the 3pt hitch, btw. That's sudden death for the inexperienced. If you have to tow something heavy and don't have a proper tow bar (between the two waggling bars at the back), fasten the chain around the front axle and back up.
If yours is a diesel, make SURE that you don't run out of fuel. I learned that last winter.
Keith Stromberg
07-16-2007 03:40:50
 Re: MF35 in reply to Rod in Smiths Falls, ON,, 07-15-2007 17:15:03
Tjamks for the information. I need all the help I can get!
Keith
