DELUXE 35 CLUTCH PROBLEM
THE BIG RON
10-14-2000 11:35:02
I HAVE A FRIEND WITH A GAS DELUXE 35 AND A 3 SPEED HI/LOW TRANSMISSION. WHEN HE PRESSES THE CLUTCH PEDAL THE TRACTOR WILL NOT STOP. CLUTCH PRESSURE SEEMS TO BE NORMAL. DOES ANYONE HAVE THOUGHTS ON WHAT TO LOOK AT FIRST? THANKS IN ADVANCE.
Jack in NB
10-15-2000 12:05:06
 Re: DELUXE 35 CLUTCH PROBLEM in reply to THE BIG RON, 10-14-2000 11:35:02
Hello, Ron
We had the same problem a couple of weeks ago. Turned out to be one of the hinge pins holding the release levers adrift, allowing the finger to float.
This style of clutch has short roll pins securing the hinge pins; two had loosened and come out.
Visible through the inspection cover under the flywheel/bell housing, unless a loader frame interferes.
Had to split tractor to repair. 8 - 10 hours.
I have some reassembly notes available if you have to split - it's easy to damage the clutch without careful handling when sliding the halves together.
