MF35 gear/hydraulic oil milky
Laurence Lombar
07-14-2007 23:29:14
The gearbox/hydraulic oil in my MF35 is quite milky. Is it a big problem and should I change it? I think I have changed it before and it did not take that long to get milky again. Milkyness is probably due to water but there is obvious entry point for any water.
DavidP, South Wales
07-15-2007 05:38:25
 Re: MF35 gear/hydraulic oil milky in reply to Laurence Lombard, 07-14-2007 23:29:14
Hi,
Contamination by water is the usual source of milky oil. The point of entry is often perished rubber boots on the gear levers. These should be checked and replaced if necessary. Are you operating any equipment that has stood for some time or may have collected water in some way?
Regards
DavidP, South Wales
Keith Stromberg
07-15-2007 06:46:36
 Re: MF35 gear/hydraulic oil milky in reply to DavidP, South Wales, 07-15-2007 05:38:25
I have the same problem. I have been letting it drain for two days now and its still not all drained out yet. This tractor sat for a few years out in the weather, and the shifter boots were in very bad shape. I have been wondering should I try and flush it with something. Also I have seen that there is a hyd. filter listed for it in the parts, but I do not see were it is in the I&T manual? Do you have any idea about this?
Keith
TomTex
07-15-2007 20:41:53
 Re: MF35 gear/hydraulic oil milky in reply to Keith Stromberg, 07-15-2007 06:46:36
Keith, use the IT manual for a good door stop, and get yourself an Operator Manual, a Repair Manual, and a Parts Manual - all real MF. Problem solved. They will pay for themselves in the long run. Tom
MF Poor
07-15-2007 08:15:22
In addition to the shifter boots, water can infiltrate the hydraulic sump through a leaky master control spring boot, or a missing dipstick. Shifter boots are #1 concern though.
Often times when people drain the hydraulic sumps on these tractors, it's overlooked that there are TWO drains. One is under the transmission. The other is under the rear end housing. BOTH drain the same sump, but it takes BOTH being opened to drain all the oil. Leave one or the other, and you leave about 2 gallons of old oil in the system.
To flush, I've drained hydraulic sumps, filled with several gallons of diesel fuel (or mineral spirits) and then GENTLY drove the tractor a few minutes (with NO load) then drained again. I do so with 3-point lift in down position. You will be astounded at how much crud that will wash out. Allow it to drip dry. Diesel fuel is a light-weight lubricant. It won't harm gears and such so long as it's just used to flush system. Re-fill with proper amount of correct oil.
Filter is accessed behind the right side inspection cover, located near where your right foot would sit on the running board. SOME earlier models didn't have a filter/screen.
