250 mf No power
Scott's B haven
07-11-2007 18:30:07
My 250 has low hours and has always ran great. I pulled it out of the barn last week and it sounded like it was running on two cylinders.
So I changed the fuel filters and bled the lines
and it still sounds bad and as you give it full throttle it puts out black smoke which it never did before. Any help would be great,As I don't know a bunch about diesels. Thanks Scott
Don-Wi
07-12-2007 00:26:05
 Re: 250 mf No power in reply to Scott's B haven, 07-11-2007 18:30:07
Did the mice happen to plug up the air intake? It's worth a look....
Donovan from Wisconsin
DavidP, South Wales
07-11-2007 23:58:10
Hi,
Before removing the injectors;
There should be a filter on top of the tap in the fuel tank. Make sure you have an adequate flow of fuel to the lift pum and that fuel is being pumped by the lift pump. Check your air filter and hose to the inlet manifold. A collapsed hose will cause all sorts of problems.
If everything appears to be OK slacken the injector nuts one at a time. The one that cuses the engine the least difficulty will point to where the problems and the one which will probably stall the engine is the one that is working well.
Please let us know what you find.
DavidP, South Wales
07-11-2007 19:06:20
I would look at the injectors. They may not be atomizing the fuel. The pump would be the second place to look. The black smoke makes it obvious a fuel issue, expecially if there is a power loss and missing.
