MF FE 35 Diesel electrical
Opha R. Kesling
10-13-2000 05:06:21
I have a mf fe35 diesel Serial# SNMY 360988 I can't find a service manual or any info. on the tractor.
model year? positive or negative ground? why it has 2 solenoids? is the wireing diagram the same as a TO35 diesel?
HELP !!!
Jon in Aus
10-15-2000 18:40:44
 Re: MF FE 35 Diesel electrical in reply to Opha R. Kesling, 10-13-2000 05:06:21
Sorry, didn't answer your question, if we are talking about the SMC Diesel its positive earth. But I'm sure you are aware you can change this, but why you'd want to...
Jon in Aus
10-15-2000 18:37:53
I have a 1958 FE35 with a Standard Motor Company Diesel engine. I have a manual which covers the TO series and the FE35. Its a bit brief, can't remember who publishes it, but you would probably find it on Amazon.com.
The wiring is VERY basic and certainly does not have two solenoids (are they both working?). The only tricky bit is the Neutral Gear safety switch. Sounds like someone has tried to fix something and added the second solenoid.
