Microbrake? 1130
Reaver
07-09-2007 15:06:49
I have an 1130 Massey...when I got it, it has a bolt in the park position on the shifter (so you do not use park) and it has some type of a hydraulic park brake with a small lever mounted on the fender for on or off on the brake. Basically, when you get ready to shut off the tractor you push the left brake and turn the lever to on...worked good for a while, now it does not want to release properly, so I got to the point that I quit using it and just put a block in front and behind one wheel and park on fairly level ground....any ideas on how to fix appreciated. I have read some prior post on the 1130 and it seems park has been a problem on them, so probably don't want to remove the bolt and use park?...you agree?
Thanks for your input.
Reaver
brianriver
07-10-2007 14:01:37
 Re: Microbrake? 1130 in reply to Reaver, 07-09-2007 15:06:49
Ninety percent of park problems was a bent park lever that goes through the parl cover bolted to the left side of transmission housing. Pretty simple fix once you drain down tranny oil and remove most of the fuel to swing tank out to get to the cover bolts. Weak point on a good tractor, never shift into park until completely stopped.
