Delco distributor again
Randyr
07-03-2007 16:30:26
Was in a hurry, but did get a chance to check the upward travel on the shaft. Without measuring it feels like I can lift it about 1/16th of an inch without it turning. Is this within acceptable limits? Could it cause spark scatter?
Would installing a shim under the distributor to take up the slack reduce the scatter. These are sold at Jeg"s for just this purpose.
Thanks.
Jerry/MT
07-03-2007 18:35:21
 Re: Delco distributor again in reply to Randyr, 07-03-2007 16:30:26
The allowable vertical play(end play), per the Ferguson Shop Manual is 0.010" and is adjsute with a spacer washer and shims. If you have a sixteenth of an inch, that's 0.0625". Better measure it with a dial gauge but if it's that big you need to get it within limits. I don't think it will affect the spark but I believe it will effect the timing because of the angle that the gear teeth are cut.
