needle adjustment for massey ferguson balers
Don Decker
07-02-2007 11:43:10
help keep breaking needles how do i shim are what do i do please write back real soon thanks was timed but cant get needles adjusted
JW in NH
07-03-2007 05:34:40
 Re: needle adjustment for massey ferguson balers in reply to Don Decker, 07-02-2007 11:43:10
MF#3,12,21 all use the same Knotters and timing. Get a manual from the MF dealer and follow the instructions: I have had great luck by using the minimum settings: example if it says 3/32 to 1/8 shot for the smaller number. Most of the balers I have worked on are so worn, that the tolerance needs to be tighter. Sorry I could not get you the excate information, My manual is with the baler in the field. One more thing I would recommend turning the baler by hand 1/4 turn or less through out the adjustments: It makes it easier to see where things are not lining up correctly. Key on the opening in the needle as the points are usually different from wear or casting. I like to use the top of the opening as my reference point. Good Luck and take your time.
JW in NH
Don/NY
07-03-2007 23:19:43
 Re: needle adjustment for massey ferguson balers in reply to JW in NH, 07-03-2007 05:34:40
JW thanks for getting back to me. I will try your suggestions and hope they work!. P.S. Everything i do with this machine takes time.Thanks again.Don/NY
TomTex
07-02-2007 19:45:26
Manuals are cheaper than needles. See if your MF dealer can order you an Operator Manual and a Parts Manual. Tom
JW in NH
07-02-2007 11:45:29
What model baler???
don decker
07-02-2007 19:38:32
 Re: needle adjustment for massey ferguson balers in reply to JW in NH, 07-02-2007 11:45:29
baler is actualy a massey-harris #3 square baler but the people that i have talked to say the massey-ferguson is the same??? Thanks if you can help.
JJ. in BC.
07-02-2007 20:26:27
 Re: needle adjustment for massey ferguson balers in reply to don decker, 07-02-2007 19:38:32
If you email me i will scan the relevant pages for you..... ....JJ.
Don Decker/NY
07-03-2007 23:10:25
 Re: needle adjustment for massey ferguson balers in reply to JJ. in BC., 07-02-2007 20:26:27
jj any help you can give me would be great! Thanks very much.Don
