MF 255 lube
the big MF
07-01-2007 09:44:12
what fluid is in the transmission and rear of a MF 255? Is it hydraulic oil or gear oil or something else? Thanks for any help
MF#1
07-01-2007 18:41:18
 Re: MF 255 lube in reply to the big MF, 07-01-2007 09:44:12
Perma-Tran III or equivalent which is hydraulic fluid for wet brakes, hydraulics, and transmission. Pour in the 1-1/16 head plug next to the main gear shift lever. Check level with dipstick behind right foot rest. Would suggest you buy an operators manual from dealer or elswhere. That"s a great tractor!
pbutler
07-11-2007 10:49:52
 Re: MF 255 lube in reply to MF#1, 07-01-2007 18:41:18
Awesome Tractor! Easy to drive and bulletproof Perkins.
Get a manual! Try to get one for the year you have, as some changes were made over the years-wet vs dry, gas vs diesel, etc. I made a mistake with mine the 1st time and filled the planetaries separately-but on mine they use the same fill as trans-then bought a manual. I use Permatran III.
