MF 188 MULTIPOWER Knocking sound
John R B
06-28-2007 07:42:06
Hello my Brother was using our 1974 188 to do some pasture topping yesterday after a few times round there was a knocking sound he the it was the engine at first but the noise is coming from the gearbox area everything appears to be working the multipower goes in and out ok anyone know what its likely to be.
John R B
07-01-2007 06:57:22
 Re: MF 188 MULTIPOWER Knocking sound in reply to John R B, 06-28-2007 07:42:06
Hi yes it does become louder when the loader is in use so it sounds like thats what it could be
DavidP, South Wales
06-28-2007 15:02:18
Hi, does the sound change or go when the implement is being lifted? It is possible that you have a broken pump dowel pin. These are located on the handbrake linkage pivot point. They can be easily checked but you will have to lower the oil level first. You will also need to inspect the condition of the locating hole in the front end housing of the pump.
DavidP, South Wales
