MF sickle mower
dracos
06-24-2007 19:47:48
I have a model 32 mower that when I go to cut the grass constantly sticks on the bar and binds up, I would appreciate any ideas or help with this.
thanks mike
DavidP, South Wales
06-25-2007 06:03:52
 Re: MF sickle mower in reply to dracos, 06-24-2007 19:47:48
Hello,
Grass clogging is generally due to wear in the sicklebar or cutterbar as they are referred to in the UK. Sometimes it is due to the grass being like a mat or laid flat.
Wear occurs on the blade bar, the wear plates underneath the blade and on the caps. The plates are shimmed and adjustable to to take up most wear as it occurs. Place the cutterbar on flat ground and shim up until the blade is just free to move with a liberal oiling. Check for blunt or bent finger points, loose, bent or blunt blade sections.
DavidP
dracos
06-25-2007 06:40:39
 Re: MF sickle mower in reply to DavidP, South Wales, 06-25-2007 06:03:52
Thank you for the information, its much appreciated.
