Z-145 Continental Rod Cap Bolt Locks
Tom from Buckey
06-22-2007 06:23:04
I have the engine on the stand after new sleeves installed. Crank is in and fitted.
Question: The rod cap bolt locks,the little flat things that bend against the hex, are broken and I went to three places yesterday looking for replacements, no luck! Two of the three shops suggested lock-tite, what do you think?
Thanks, Tom
Fred Wolfe
06-22-2007 09:01:00
 Re: Z-145 Continental Rod Cap Bolt Locks in reply to Tom from Buckeye Lake, 06-22-2007 06:23:04
Do you have the massey part number?
06-24-2007 07:11:22
 Re: Z-145 Continental Rod Cap Bolt Locks in reply to Fred Wolfe, 06-22-2007 09:01:00
My old parts book number is 1 750 042 M1
Thanks
DavidP, South Wales
06-22-2007 07:56:18
Hello Tom,
You are referring to the main bearing cap bolt tabwashers. A similar thing has happened with the the early Perkins AD3.152 engines. Tabwashers are no longer available. The response which I believe has come from Massey Ferguson is to increase the tightening torque by 5 to 8 lb-ft. We have never had one come loose that this was done on.
As far as Loctite goes I wonder whether you would be able to get the femaile thread clean enough for the Loctite to work. Using it is not something that I would wish to do.
DavidP, South Wales
DavidP, South Wales
06-22-2007 07:57:30
 Re: Z-145 Continental Rod Cap Bolt Locks in reply to DavidP, South Wales, 06-22-2007 07:56:18
This would refer to the con-rod bolts as well.
DP
