oil ring for MF 135 stuck or broken
scott reed
06-18-2007 11:58:20
How can I tell if an oil ring is stuck or broken? How much to fix? Can I add diseal to oil?
DavidP, South Wales
06-18-2007 15:10:03
 Re: oil ring for MF 135 stuck or broken in reply to scott reed, 06-18-2007 11:58:20
Hi,
You may see dampness around the crown of the piston and streaks of oil in the bore as the piston descends. If you suspect ring problems then really the only way is to remove the cylinder head and sump and remove the pistons to check the condition of the rings. A compression test will help a little but that is for compression not oil clearing ability.
DavidP,South Wales
