MF 3 point hitch will not lower
Paul K.
06-16-2007 16:21:47
I have a 1957 MF 65 Special.
The 3 point hitch raises all the way up with considerable force when I start the engine and it will not come back down unless I shut the tractor down and wait an hour or so for it to slowly lower. I idea what might be causing it to stay all the way up? I changed the hydraulic fluid twice thinking it might be dirty.
DavidP, South Wales
06-17-2007 13:15:02
 Re: MF 3 point hitch will not lower in reply to Paul K., 06-16-2007 16:21:47
Hello,
I think that your problem may be a broken oscillator. This link is driven by the eccentric movement of the pump shaft cam and keeps the control valve body moving to ensure that it does not stick during operation. 35s, 65s and early 100 series tractors had an aluminium oscillator which was prone to break. Later ones were made of metal and never failed. Drain the oil to the level of the bottom bolt on the RH side cover and remove the cover. With the engine off, operate the quadrant controls. The lever on the pump should respond accordingly. In this case I believe it will not. It will remain in the 'pumping' or 'lift' position.
DavidP, South Wales
