LIFT MF TO35
MICAH
06-15-2007 08:49:20
I NEED SOME EXPERT ADVISE, THE LIFT BLEEDS OFF UNDER LOAD. IS THERE A CHECK VALVE IN THE COVER OR
DO I NEED TO RESEAL THE CYL? I WAS TOLD TO PULL THE DIFF COVER AND INSPECT AND FOUND FLUID RUNNING DOWN FROM TOP WITH ENGINE RUNNING AND LOAD ON 3 POINT. AND IF I NEED TO RESEAL THE PUMP
WHAT PARTS OR PROCEDURE WILL I NEED TO FOLLOW?
Jerry/MT
06-15-2007 10:14:14
 Re: LIFT MF TO35 in reply to MICAH, 06-15-2007 08:49:20
"Fluid running down from the top" is indicative of leaking piston seals or a cracked cylinder. In either case you'll have to take off the lift cover. You'll need a shop manual to guide you so you can get it off with out damaging the control mechanism.
MICAH
06-15-2007 12:26:49
 Re: LIFT MF TO35 in reply to Jerry/MT, 06-15-2007 10:14:14
THANKS JERRY/MT FOR THE INFO. I WILL BUY A MANUAL AND REMOVE THE LIFT COVER TO INSPECT THE PISTON SEALS AND THE CYLINDER
