MF 130 3 pt won't lift
Cory Fregm
06-09-2007 18:27:13
I posted this in tractor talk, but maybe some MF experience will answer this simply. My 3 pt will only lift about 150#, anything more it will not raise. How to determine if fluid is low? Is this likely, or perhaps a weak lift cylinder? Just bought it and headed straight for the garden, hard to drive around with the plow in the ground!
bw in NC
06-09-2007 19:06:30
 Re: MF 130 3 pt won't lift in reply to Cory Fregm, 06-09-2007 18:27:13
you should be able to check the fluid with a dipstick on the left side under the seat near the pto lever, I think if its not there then its on the other side. Low fluid could cause that, make sure to check that. I have never worked on a 130 but I have others I doubt they are much different. Check the .....
Filter, I don't know if there is an external filter on a 130 if not there should be a screen underneath the tractor that could be clogged, be sure to drain the fluid out first before you check this.
make sure the draft is in the all the way up position. If all that checks out then it could be the pump or either the lift cylinder. Does the lift come up all the way with nothing on it? If it does, cut the tractor off with the lift in the up position. Does the lift leak down, If so my guess would be the lift cylinder. anyway hope this will help you.
Joske
10-22-2007 02:47:37
 Re: MF 130 3 pt won't lift in reply to bw in NC, 06-09-2007 19:06:30
You can check the transmission oillevel at the back. Look at the PTO, you"ll see a nut, unscrew it and the oil should be level with the opening. If the oil is ok, check your transmission filter: in front of the seat. Put in a new one if necessary. Also check the filter in the back when you renew the oil.
Paul Patrick
06-11-2007 07:58:01
 Re: MF 130 3 pt won't lift in reply to bw in NC , 06-09-2007 19:06:30
I have a similar problem with my 130. It lifts pretty well when it is cold, but after using it awhile,it will barely lift the 7' blade off the ground. Also I zero draft control - the lift is either all the way up or down - no in between. I'm going to change the fluid and filter when I get more time and see if that helps. I need a new steering wheel, tie rod end, and a few other parts. Replacement parts for these little tractors sure are hard to find.
