t035 lift bleeds off
Micah Elam
06-09-2007 10:16:32
I have an 59 massey to35 that the 3 point lift bleeds off with engine off or clutch in. It seems to lift just fine but will not hold a load. Is there a check valve or do I need to reseal the cyl? I was told to raise lift and pull pto cover
off and watch for leaks from cyl which it does have with a load on and drains down. Any advise would be appreciated.
marlowe
06-09-2007 11:49:06
 Re: t035 lift bleeds off in reply to Micah Elam, 06-09-2007 10:16:32
it's not the pto cover it's the side covers on the side of the diff. one has the pto lever other the dip stick
Micah Elam
06-11-2007 08:17:56
 Re: t035 lift bleeds off in reply to marlowe, 06-09-2007 11:49:06
Ok, that is what I took off. I have pulled the diff covers and noticed fluid leaking down, do I need to reseal the pto lift cyl. to stop the bleeding off? Thanks for the help.
