Hi,I am considering buying a MF 135 - 3 cyl diesel, with loader, that appears to be in very good condition. It appears to be a 1974 UK model as the Serial No. is 442768M, and has twin power steering cylinders at the front. I have checked all the things on Big Dean's checklist and everything checks out fine. There are no leaks anywhere, power steering is fine, and the hydraulics seem fine although I do have a question (see below), because I am not familiar with how they should work. The only guage not working is the temperature guage. Is this easily fixed? The hour meter is showing 6662 hrs. I am a little concerned about the brakes as they do seem to work, but you have to stomp on them hard and it takes a while to bring the tractor to a stop. Is this normal braking for a used 135? I think the dealer is asking top price for it at $9000 CDN. Is a 135 with loader in very good condition worth that much? I do have a question about the hydraulics. It seems that you cannot run the hydraulics to the 3pt hitch and the front end loader at the same time. There is a small knob under the seat which when moved back activates the hydraulics to the rear 3pt hitch. When it is moved towards the front position the draft lever has to be at the top position and the Up/Down lever needs to be in the "Constant Pumping" position in order for the front end loader to work. Is this the way it should work? I currently own a 1950 Harry Ferguson in good running condition and would like opinions on what it would be worth as I am considering trading it in on the MF 135. Thanks for any and all advice, Richard
