65 wiring diagram lp motor
Rex Whiteside
06-04-2007 11:41:48
anyone have a wiring diagram for GB176 Cont. LP motor. tried to start tractor this weekend,and when I hit the starter button all I got was a buzzing from the solinoid. replaced the bat. cables and solinoid. same results but now the on off switch starts smoking when I hook up the batt. Help!!!
John Caufield
07-03-2007 11:43:29
 Re: 65 wiring diagram lp motor in reply to Rex Whiteside, 06-04-2007 11:41:48
Try running a new ground from the engine to the chassis sounds like you have lost the ground. You said you replaced the battery cables but did you clean the area where the ground cable hooks to the chassis
