PERKINS A3-152 VALVE ADJ
fe 35er
06-01-2007 21:23:23
Just a quick question that my manual doesn't awnser. Is the clearence measured between lifter and rocker5 or is it between the rocker and valve tip?
Many thanks ahead of time.
Greg_Ky
06-01-2007 23:05:34
 Re: PERKINS A3-152 VALVE ADJ in reply to fe 35er, 06-01-2007 21:23:23
Between the rocker and valve tip.
DavidP, South Wales
06-02-2007 11:16:13
 Re: PERKINS A3-152 VALVE ADJ in reply to Greg_Ky, 06-01-2007 23:05:34
Hi,
There is an interesting contradiction here. We have always checked the clearance between the rocker and the tappet on three cylinder engines.
The MF workshop manual for the 500 Series confirms this for the three cylinder and AD4.203 engine.
However for A4.236 and A4.248 engines with pushrods it is checked at the valve stem as you would expect.
Cheers
DavidP, South Wales
